1 members (baldeagle),
93
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57264 03/03/2006 4:28 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | I was checking out a guys 59 apache and his 235 has a big Down draft tube on the passenger side of the block. My 59 with a 235 doesn't have one. Was their a change in models or where the engine was manufactured, or was their something that the PO did to my 235? | | |
#57265 03/03/2006 5:08 PM | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | I dont know at what time, but chevy went to using a pvc valve instead of the old draft tube. | | |
#57266 03/03/2006 5:34 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | All 235s have a spot for the tube. I know California cars had it blocked off and used a PVC system as far back as 1954 and maybe earlier, Washington cars used the tube through 1962.
See the USA in your vintage Chevrolet! My Blog | | |
#57267 03/03/2006 11:55 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Some big trucks had a pcv system also. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#57268 03/04/2006 1:39 AM | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | Dave, you are right on with that one. The 235 in my 61 has a Road Draft Tube. How hard a swap is that?
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | |
#57269 03/04/2006 3:54 AM | Joined: Apr 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 50 | I have a '59 apache 235 with the pcv system. It was sold new in California and the pvc system looks stock.
Adam | | |
#57270 03/04/2006 3:10 PM | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | Anyone have pics of the pvc in place of the down draft tube? And showing the return to the manifold? thanks | | |
#57271 03/05/2006 2:57 AM | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | Is the pvc or down draft tube required? What would the result be of not using either of them? Or would it even matter.
1946 1/2 ton I'm not addicted I just don't know when to stop
#57272 03/05/2006 3:22 AM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | the engine has to breathe. if you dont put anything there it will work fine but you'll have an oily mess in no time. | | |
#57273 03/05/2006 4:02 AM | Joined: Apr 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 50 | The PCV (Positive Crankcase Ventilation) system also works as an emissions device, by taking the gasses in the crankcase and putting them back into the intake air to be burned again. This will reduce the HC's (gasoline) that goes out the tailpipe and pollute.
In the morning I can take a picture of the PCV system in my '59. The PCV valve attaches to the valve cover and then there is a hose that goes into the top of the oil bath air cleaner.
Adam | | |
#57274 03/05/2006 6:29 AM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | | | |
#57275 03/05/2006 6:06 PM | Joined: Apr 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 50 | The setup on my '59 is a little different than the one on the above web site. There is a hose that comes out the side of the valve cover and then to the PCV valve and then another short hose that goes into the intake manifold, right under the carb.
There is a separate hose that goes from the top of the valve cover and then into the air cleaner with no PCV valve.
I always assumed this was the factory setup, but I may be wrong.
The link has a couple photos. Hope this helps.
http://www.flickr.com/photos/11159813@N00/
Adam | | |
#57276 03/05/2006 7:32 PM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I like this idea,would like to know how well it works.I also like the nostalgia look of the down draft tube. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#57277 03/07/2006 4:36 AM | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | I was hoping to avoid that hose look and have the simple look. Is there a performance issue here or is it for more current smog laws that won't apply to my 46. Thanks
#57278 03/07/2006 6:17 PM | Joined: Apr 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 50 | I don't think you will gain or lose any performance using a PCV valve. The carb will be adjusted to suite the needs of the engine anyway. The PCV is more for smog. Just make sure the crankcase can breathe in some way.
Adam | | |
#57279 03/09/2006 3:50 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Thanks guys, My truck was made and still resides in California.
California…always has to be different.
What symptoms can accrue when the PVC valve gets clogged? Or does it ever get clogged? I know they do on Mopar 318's. | | |
#57280 03/11/2006 4:57 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Has anyone tried simply drilling the down-draft tube for a grommet and PCV valve at the top. I think a low mounted valve in the draft tube hole would pick up more oily fumes and the additional 5-6" higher mount on the top of the road draft tube would work out better. Obviously, the valve cover mount with a baffle under the valve would be the optimum if you didn't mind drilling your cover and mounting a baffle (which is a MUST) This way the tube, which would be plugged would serve as the baffle to keep splash out of the valve.
Lack of a PCV valve and a plugged draft tube will fix you up with excessive crankcase pressure, oil leaks and some sludged up oil pronto. Just my $.02....gained from.... | | |
#57281 03/12/2006 5:08 PM | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | Guys there was a previous post on this with very detailed explanation.
here is the link ... http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=009879#000001 | | |
