0 members (), 129 guests, and 1 robot.
Topics128,115
Posts1,056,292
Members48,439
#572043 09/07/2009 2:55 AM
Rebuilt engine what kind of oil would you recommend on breaking it in with.
John Deere break in oil. After the break in, any good, high quality, multi-viscosity oil, with a high detergent.
30 weight non-detergent with either GM EOS suppliment or Competition Cams break in lube. I personally prefer Valvoline.
Bill Burmeister
GM supplement is ?
Do you think running engine for about lets say 1000 rpms for 20 minutes would be sufficent
Engine Oil Suppliment. Should be able to get it either from any parts store that is an AC/Delco dealer or the GM dealership parts department. Most guys use 2 bottles of it (I did).
For break in, you'll want to run about 2000-2400 rpm, varying the rpm during the process, for about 20 minuits. Don't let it idle at all. If you need to idle, shut it down, do whatever you need to do, then restart ( I had to do that, didn't put enough feul in the tank). Change the oil and filter. You'll also want to go through the valves.
Bill Burmeister
patrick's says z-d-d oil additive and valvoline vr-1 oil. and several places say to re-torque the head bolts while the head is still hot
rednate #572067 09/07/2009 4:20 AM
Retorqueing the head will depend on what gasket is used. many modern head gaskets do not require retorquing. You'll want to consult the gasket instructions to determine if you will need to do that.
Bill Burmeister
LONGBOX55 #572114 09/07/2009 11:14 AM
Thanks for the info.
composite/copper gaskets require it?
rednate #572227 09/07/2009 7:51 PM
Copper gaskets do, composite gaskets can vary, depending on what it's made of. I personally use Fel-Pro, and did use a composite gasket on mine. It did require retorqueing. But as I noted, gasket technology has changed over the years, even in the years since I assembled my engine. Many newer gasket material have gone to the no-retorque style. The instructions that come with the gasket set, which will also tell you what kind of sealers you should use with which gaskets if needed, will say whether it requires retorquing. If it doesn't say, though, then retorqueing would be a good idea.
Bill Burmeister
yeah, the fel pro complete set caught my eye, but i didn't know if $90ish bucks was a fair price for quality, or mostly paying for a name
rednate #572234 09/07/2009 8:17 PM
I swear by them. I've had problems with other brands not having the right fit. Plus, pretty much all of the parts I use both on my own vehicles and customers vehicles come from Federal-Mogul (parent company of Fel-Pro) because I like the superior quality.
Bill Burmeister
LONGBOX55 #572289 09/08/2009 12:19 AM
rednate,
1950 CHEVROLET TRUCK 3.5L 216cid L6 : Engine : Engine Kit Gasket Set
FEL-PRO Part # FS7276B2 for about $62 plus shipping (and no tax) at Rockauto.com
What year and size engine are you referring to?
Tim
tc - my truck is a '50 3100 with a 216, but i'm rebuilding/putting in a '61 235
rednate #572373 09/08/2009 3:45 AM
Rockauto.com: 1961 CHEVROLET C10 PICKUP 3.9L 235cid L6 : Engine : Engine Kit Gasket Set
FEL-PRO Part # FS7619B3 More Info {FULL SETS (FS) are for upper and lower engine work combined, usually a complete overhaul.}
Fiber-faced head gskt. material $60
FEL-PRO Part # FS7619C3 More Info {FULL SETS (FS) are for upper and lower engine work combined, usually a complete overhaul.}
Copper-faced sandwich head gskt. material $65
$63.99 at O'Reillys. Once you pay the shipping fees, the price is probably about the same.
Bill Burmeister
excellent - thanks you both
now what about an auto/hyro, street/some hop, cam shaft?
