0 members (),
119
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57223 03/02/2006 2:04 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | The beautiful tech tip did not mention my type of dust cap. My 55.1 has dust caps with no retaining ring or retaining ring groove in the spindle. The kit I got does not have retaining rings either. Do I just hammer the dust caps into the holes for a press fit? Do I put some grease in on the ends of the king pins before I hammer the dust caps in? Thanks - Scott
55 1st Chev.
#57224 03/02/2006 2:52 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Scott: Yes it would not hurt for a little grease. What I did was find a extended socket for a exact fit then hammer on the extended socket thus driving the cap into place.
popcorn The Truth is Out There (Worked good for me) Ben | | |
#57225 03/02/2006 2:58 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Thanks, that would prevent pounding the humped center down flat. I assumed the hump goes up and that should keep it up. Great thanks - scott
55 1st Chev.
#57226 03/02/2006 3:26 PM | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | They're a real pain in the a** to get seated properly... Popcorn's right placing a socket over it let's you hammer it down allowing equal pressure all around. You'll know if you got it on right when you grease the king pin. If it's not on tight the pressure from the grease will pop it off. And yes, hump goes up (we're talking dust cap here right?) | | |
#57227 03/02/2006 6:44 PM | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | I like to give that dome a little dimple to wedge it against the side. Has anybody mentioned to stake it good to keep it from falling out after it has been on the road a few miles?
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#57228 03/02/2006 6:46 PM | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | What does "stake it good" mean? | | |
#57229 03/02/2006 8:44 PM | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | I am not sure how best to describe "staking", but it involves making an indentation that crosses the dust cap and the knuckle surface. What this does is "swell" the two areas together. If you look at this area on your axle, you may see past evidence of this procedure. If you do not file/grind these little bumps, it will make putting the dust caps harder to put back on. I hope this explanation was clear. Someone on this board WILL correct me, so stay tuned.
#57230 03/02/2006 8:56 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Staking is the process which you force a corner of one metal over another. Usually you can take a punch and knock down a piece of the outside metal ontop of the inside metal. We use to stake a nut to the bolt thread w/punch. This is before loc-tite or lock nuts.
popcorn The Truth is Out There (49 not trying to correct you just trying to make it simple. Ok I know clear as mud. LOL ) Ben | | |
#57231 03/03/2006 7:07 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I believe staking in this case does refer to burring or making several slight notches in the top and bottom of the spindle bore to prevent the cap from coming off. I think that it is illustrated in one of the manuals. | | |
#57232 03/03/2006 10:51 PM | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | Don't apologize popcorn! I am just glad people on this board have the vocabulary to explain the correct usage of all these durn "mechanical" terms.
#57233 06/16/2006 8:17 PM | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | I'm glad I just came across this topic (yes, I used Search). I am in the midst of replacing my king pins. It looks like someone before me staked the crap out of the spindles. I worked on getting one of the dust caps off for a few days before success. I finally gave up on the others and took the whole assembly to a shop. I just got a call from the shop saying the spindles are shot and need to be replaced because he won't be able to get the retaining rings back in. It's a '50 3100. Is this correct? Does it have retaining rings or should he be staking them in? I didn't see any on the axle before I took it over there or in the kit I received.
Thanks. RedGreen | | |
#57234 06/16/2006 8:25 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Mine was a 55.1 and had no retaining rings, and it was not staked. They stuck in there just fine with a press fit. But that's a 55.
scott
55 1st Chev.
#57235 06/16/2006 8:57 PM | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | Your 1950 3100 stock from the factory had no "retaining ring". He should "stake" them so the dust covers do not fall out.
