0 members (),
166
Mod | | | Forums66 Topics128,196 Posts1,057,386 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 46 | my 52 is running,the only items to adress is heat.i need to replace my 6v motor with a 12v and my heater core looks ok but am questioning it anyone have any luck with an aftermarket product? (it would be new motor and heater core) i use this truck around the place so stock is not that important, thanks for any input in advance trying
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | If You go to NAPA or mabe Your FLAPS they can get You a 12 volt motor the same size as Your 6 volt so that would be done I am not sure about heater core I know that places like Jimmy Carter sells them but there are a number of different heaters so You would have to match that up.There are after market under dash heaters if You do not care about stock they look like space heaters but smaller and would have 12 volt motor .
Pete | | | | | Joined: Jul 2004 Posts: 2,995 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,995 | Years ago, we transplanted a heater from a Hiniker tractor cab into an old AD farm truck my Dad had. It wasn't intended to be anything fancy--just a means of getting some warm air into the cab. But if I recall correctly, it was just a small square unit that didn't take up a lot of room. I think we just bolted it up under the dash in the usual spot and ran the heater hoses to it as usual. My brother works for Hiniker, so we were able to get it REAL reasonable!!
Don't know if this is of any help, but just thought I'd throw it out there. | | | | | Joined: Jul 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 33 | Summitt Racing has a nice metal unit that I put in the '46.It has a three speed blower and is decently priced at around $140. Seems to be a solidly built unit, I've ran it for the last part last winter and it really made driving the old truck a pleasure. | | | | | Joined: May 2005 Posts: 6 New Guy | | New Guy Joined: May 2005 Posts: 6 | Hey Joe H - get you a cable operated heater shutoff valve and install it in the heater hose. You can control the temp with the amount of flow. It works. | | |
