9 members (VicZ, Ridgeback, RAC1812, Shaffer's1950, Gdads51, artinva, klhansen, Otto Skorzeny, 1 invisible), 122 guests, and 1 robot.
Topics128,077
Posts1,055,928
Members48,430
#57198 03/01/2006 7:07 PM
I've been trying to tune my Rochester B 1bbl and haven't had much luck with it yet. Its on a '66 250. I'm just trying to increase my gas mileage. If you have any tips or if its a lost cause, let me know.
Drew
'66 C-10 stepside
#57199 03/01/2006 10:54 PM
Riding in the Passing Lane
Take the top off & check the float level. Make shure the power valve woks up & down & knocks the ball off it,s seat. Make a note of the size of the main jet. It is stamped on the jet but takes better eyeballs than this old man has unless I use a magnafying glass. Make shure the vacuum advance is working & set the timeing about 8 degrees BTDC. If the engine pings on accelleration set it back a little. Turn the idle mixture screw in slowly with engine running till the engine starts slowing down. Than back it out a little to smooth it out. Try all that & if the mileage is still not good enough we can start reading plugs & changing jet sizes.
1972 Chevy c10 Cheyenne Super
