7 members (TUTS 59, homer52, Otto Skorzeny, Youngin' Tut 59, dt235sd, 2 invisible), 122 guests, and 1 robot.
Topics128,052
Posts1,055,727
#57160 03/01/2006 2:54 AM
My 50 3100 with 3-speed and stock rear end has a loud whine when I take my foot completely off the gas at 30 mph or higher. If I put the clutch in, the whine stops. When I restored the truck I took the carrier assembly completely out to clean things up. When I reinstalled it I used a dial indicator to set the lash according the shop manual. Is it likely that I did something wrong adjusting the carrier bearings? Or could this whine be caused by incorrect shimming of the pinion? The shop manual shows a special angled tool for reaching into the housing to measure the clearance, but I had no idea where I would ever find one of those so I didn't check it. This truck goes into an auction in August, so I need to get this fixed. Help!!
#57161 03/01/2006 3:49 AM
Change the pinion to ring clearance and test drive. if you are sure it is in the rear.
"It ain't a truck if you can't hose out the cab."
#57162 03/01/2006 12:50 PM
check the pinion nut to make sure it is tight if tight you reset the diff when you changed the back lash thus you have gear noise because the diff already had a wear patteran before you changed it...
#57163 03/01/2006 11:12 PM
Riding in the Passing Lane
Grab the pinion flange. There should be no up-down play. Pull the cover & try to move the ring gear & carrier side to side. There should be no play there either. Get some gear marking compound & check the gear contact paterns. Compare it to the shop manual chart. If it is not right move the carrier in or out by loosening the adjuster on one side & tightening on the other. Keep experimenting till you get the best pattern than snug the adjusters up & put the locks back in. The amount of backlash is not important unless it is way out of spec.
1972 Chevy c10 Cheyenne Super
#57164 03/02/2006 12:15 AM
My 1960 Truck manual say's if there is a noise when coasting it could be:
1-Ring gear & pinion adjustment too loose.
2-Pinion bearings rough.
3-Excessive end play in pinion.
So from reading your post I would have to go cause #1. Let us know what you find.
Jim
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#57165 03/02/2006 12:48 PM
did you peload the carrier when installed??did you have the pinion removed???do you know if the diff was ever quiet???
#57166 03/02/2006 5:31 PM
You're in Casa Grande Arizona? The same town as Patrick's Antique trucks? I'm jealous. I would go over there and snoop around and if you could convince him to take a ride I bet he could tell you exactly where the noise is from and give you a quote to fix it if you wanted.
http://www.patricksantiquecars.com/
Curt B.
You Tube
