| | | Forums66 Topics128,113 Posts1,056,613 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57154 02/28/2006 9:15 PM | Joined: Oct 2005 Posts: 37 Apprentice | | Apprentice Joined: Oct 2005 Posts: 37 | I have recently started to pull the engine apart. It is at my mechanic/good friends shop. We went to pull the pulley off the crank, and there was no nose bolt. He seems to think it has been broken off. Another guy I know told me that there was never a nose bolt and that the straight 6's had the pulley pressed on. Anyone know the right answer? | | |
#57155 02/28/2006 9:33 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you can trust 'the other guy', and get yer mechanic a shop manual! the depression in the end of the crank is where the the puller sits, attached w/ the 2 or 3 bolt holes in the balancer - if he doesn't have a puller, tool rental places usually rent them
if you don't have the shop manual for your year, it'd be a good investment if rebuilding an engine - everything's covered step by step
Bill | | |
