1 members (baldeagle),
87
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57140 02/28/2006 7:52 PM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | hey guys,,got a 261 head i'm having re-done. the haed no. comes back as a 57-62. it also has 858 then a space 848 on the side. got the machine shop stumped unless his book is a misprint. the intake valves that came out of it are 1.934 at the head, book says should be 1.875. the stems are .342 book says thats correct. length is 6.375, book says should be 4.888. anybody with any info on the correct intake valve size, head,stem,length. or any info on what might have been done to it, someone had put high comp. pistons in it, so who knows what else they did..thanks guys.. | | |
#57141 02/28/2006 9:01 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The 4.88 in your book is wroug for the intake valves.
The 1.934" dia. valve is used in 1950-52 powerglide engines. It is not uncommon to see these installed in the later heads.
See the USA in your vintage Chevrolet! My Blog | | |
#57142 02/28/2006 9:35 PM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | thanks for info. shops gonna do some checking, his book doesn't show that valve for 50-52. do you know if the 6 3/8 is the right length. | | |
#57143 03/01/2006 1:12 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Yes the 6 3/8" is the correct length, I have both diameter valves here. I have used the 1/16" larger valves myself many times.
#57144 03/01/2006 1:33 AM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | i thing the 848 head is a 235 head...not 261
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#57145 03/01/2006 2:27 AM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | hey 68 dave..thanks for info...shop cant seem to find where to get a set of valves for this..everything discontinued is what they're coming up with...you wouldn't happen to have part # andwhere to get....thanks a bunch. | | |
