1 members (Hotrod Lincoln),
136
Mod | | | Forums66 Topics128,281 Posts1,058,465 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 41 New Guy | | New Guy Joined: Sep 2007 Posts: 41 | I put in the serial number for my grandpa's '47 Loadmaster, and the VIN Buster said it was built in 1962. Anybody know why such a confusion? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What is the serial number?
Is it from the door plate or from the engine?
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | That probably means you entered the engine number instead of the body serial number.
VIN is a confusing term because it has a legal meaning that just doesn't fit our old trucks very well.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no it doesn't look like a 62, but 210WK4524 doesn't look like a 47 vin either and the vin buster only works with the factory designations .... not sure the pattern or model designations for 47, but I believe it should be one number, 2 letters at the beginning, which would identify the model, some one here with a 47.2 will know
Bill | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | No the truck looks like a '47 or '48. Its hard to be sure without some more specific pictures.
Try running that number as 21owk4524. It then comes out as a school bus made in November 1946 instead of as a '62. I'm betting you've been running it as 210wk4524.
So what does the title say? Either the Vin Buster and more than one of the references online are wrong, or you've got a problem with the serial number tag on that truck.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2007 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 43 | Jared Buckert
I just read your question tonight, sorry. IT seemed so familiar it amazed me!!! When I first tried to use VIN buster, my 47 loadmaster also came up as a 1962 ...Soo I started digging, rechecked my original title against the trucks serial plate on the door piller, and they looked like a match...then after fustration I figured one of the "documented" items might be wrong..bingo MY serial number on the title states:20j11459 and my serial plates looks "Really" the same. I replaced the O with a Q and guess what....yup a fat finger or bad eyes from someone down the road.... I ran your serial number on Vin Buster and replaced the O with a Q ( 21QK4524 )...Does this look like your truck ??
Your 'VIN Buster' Results ..
Serial # : 21QK4524 Mfg Year : 1947 Model : 1.5 ton Wheelbase : 161 inches Plant : Janesville, WI
Regards Loadmaster47 Bill
