| | | Forums66 Topics128,013 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 7 New Guy | | New Guy Joined: Sep 2009 Posts: 7 | I have a 1949 chevy with what I belive is a 235 engine. I'm tyring to identify the year but can't match numbers
3886848
Also has F 20 3 on passenger side under distributor. Can anyone help with this, I'm getting ready to pull and rebuild | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There will be a casting date on the right side of the block, next to where the starter sits. About the only thing I tell yo for sure about the code from by the distributor is that thengine came from the Flint plant, there should be another letter in the code. I take it that the casting number you posted is from the cylinder head? It's probably actually 3836848, they can be hard to read, especially if the engine is grimy from years of use. That head comes up as a '56 or later, so that points to at least a 235 full pressure.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Might F 20 3 under the distributor (to the left, under the distributor?) be a block casting date? If so, it would be June 20th 1953? Is the F 20 3 code in the ledge/boss in the block, to the left of where the distributor enters the block (as LONGBOX55 suspects)? If so, there should be more characters in the code. Here are photos of where the various codes are found on the block. The date above has been changed as per rednate's correction, below | | | | | Joined: Sep 2009 Posts: 7 New Guy | | New Guy Joined: Sep 2009 Posts: 7 | your right, after i cleaned it,it's 3836848. But I found another number on the passenger side that is located under the distrubutor across from the F 20 either 3 or 8 I have to pull the starter to see it better but that number 3738307?
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That casting number comes up as a '58-'62 235.
Bill Burmeister | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | wouldn't it be june 20th '53? | | | | | Joined: Sep 2009 Posts: 7 New Guy | | New Guy Joined: Sep 2009 Posts: 7 | it's actually F 20 8, the 8 and 3 look similar unless really clean. more than likely a 1958 235. Iv'e had it running several times but can't keep it running. I'm not going to fool around with it, just pull the engine and rebuild. Thanks for the help. | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | f 20 8 instead of 3 does make more sense in consideration of the casting #3738307 showing up as a '58-'62 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Something that will peg it is the engine serial number. It will be stamped on the machined pad next to the distributor, like this one. That number will give us the plant code as well as original application.
Bill Burmeister | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | The stamped # will peg it. Block casting 3738307 is listed as,
1958-62 Passenger, Std & P.G., Hyd. Cam 1958-62 Truck, Mech. Cam, Front Side Mounts, Van 60-62 only 1960-62 Truck, Mech. Cam, Front Center Mount
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Sep 2009 Posts: 7 New Guy | | New Guy Joined: Sep 2009 Posts: 7 | poking around in dad's garage, I found two transmissions to fit this 1958 235, what is the going price if in good shape? | | |
