| | | Forums66 Topics128,059 Posts1,055,825 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 8 New Guy | | New Guy Joined: Aug 2009 Posts: 8 | Hello everyone, I have 60 chevy c10 shortbed stepside p/u. I really want to lower it but cannot afford to "kit it" w/the dropped spindles and disc brakes and booster and such. I know lowering the rear is fairly straight forward by installing drop springs and possibly shorter shocks. My question is about the front...it has torsion bars that can be cranked down, but,I want to go atleast 4 inches. Will this create any problems such as to much negative camber and if so, can the upper control arms be shimmed out to correct it, I am hoping so. Thanks. | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Well, the torsion bars are adjustable, but I highly doubt you'll get it down 4 inches by doing that. Maybe an inch, if that. I've been considering lowering mine too (its a 61 fleetside) but if I do, I'm going with the "kit". But I see what you mean about it being pricey. | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | I know this is a bit of work but you might be able to swap in a later model front suspension(you get disc brakes too), which should be basicly a bolt in and use dropped spring and/or spindles. Do a search for I believe it's using a 79-87 front suspension. | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | I got a lot more than an inch drop out of my torsion bars. I have 'em cranked down pretty far, but I would say at least two if not two and a half. It looks lowered and people notice it. Now all I need to do is the back.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Kyle, how does it ride now that you adjusted the torsions? | | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | Is there any fear in backing that out too far and not having enough threads on the bolt that holds the bar?
I was just curious?
Let there be peace over your home, brother.
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: May 2005 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 31 | 1200.00 best money spent on my truck Early classic dropped spindles.  | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | C10,
When I bough my truck the PO had the front lowered so bad that if you turned and hit a bump, the tire would smack the fenders. When I had the front end adjusted the mech measured that he had lowered them at least 4 1/2 inches and noticed that the "bolts had about a 1/2" left.
Also if you do this yourself, PLEASE spray Kroll oil or PB Blaster all over the bolts and nuts. Let it soak a day and go back the next day and resoak the nuts and bolts. If not you are taking a chance to snapping the special shaped lock nut they used and THERE ARE NO REPLACEMENTS.
Jake | | | | | Joined: Sep 2009 Posts: 1 New Guy | | New Guy Joined: Sep 2009 Posts: 1 | The suggestion of using a late model front cross memeber is good, but dosen't work with a 60-61. It doesn't just bolt up like a 63 or later.
Been there.
I don't think you are going to get 4 inches cranking down on your torsion bars.
I would save my money and buy some dropped spindles.
| | | | | Joined: Oct 2007 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 102 | Chevytrucknut61,
Did you get your drop spindles through LMC? If so, what shocks did you get for the front once the spindles were installed? LMC can't tell me if the shocks in their catalog will work with the drop spindles that I bought through them?
I've got a 61 as well.
Thanks.
