0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 50 | is the ignition switched supposed to "lock" I can start my truck with a screwdriver and was wondering if thats normal?
65 chev c20
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | don't know about "normal", but it's pretty common .... there was a discussion about ignition lock behavior just recently, I think in General Truck, a worn original cylinder can do a number of tricks
Bill | | | | | Joined: Aug 2009 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 50 | i just put in a new ignition switch and new ignition tumbler. I replaced the old tumbler and switch as it looked like they were damaged from when it was stolen( before i owned the truck) I was hoping it would "lock" as flimsy as the lock is... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a repro one should have a lock position, you might question the supplier
Bill | | | | | Joined: Aug 2009 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 50 | | | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | I put a new lock and switch in mine but it seems to still be somewhat tricky in making sure that it is 100% locked... I got a feeling that I will be coming up with some way to make sure the truck won't start unless you know where the other switch is.
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
