Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 134 guests, and 6 robots.
Topics128,281
Posts1,058,471
Members48,490
#570449 09/01/2009 11:07 PM
is the ignition switched supposed to "lock" I can start my truck with a screwdriver and was wondering if thats normal?
65 chev c20
trevota #570461 09/01/2009 11:39 PM
don't know about "normal", but it's pretty common .... there was a discussion about ignition lock behavior just recently, I think in General Truck, a worn original cylinder can do a number of tricks
Flxible #570466 09/01/2009 11:43 PM
i just put in a new ignition switch and new ignition tumbler. I replaced the old tumbler and switch as it looked like they were damaged from when it was stolen( before i owned the truck) I was hoping it would "lock" as flimsy as the lock is...
trevota #570468 09/01/2009 11:47 PM
a repro one should have a lock position, you might question the supplier
Flxible #570469 09/01/2009 11:53 PM
i'll do that, thanks
trevota #570650 09/02/2009 6:24 PM
I put a new lock and switch in mine but it seems to still be somewhat tricky in making sure that it is 100% locked... I got a feeling that I will be coming up with some way to make sure the truck won't start unless you know where the other switch is.
Jesus is Lord!
Only through the blood of Jesus are you washed clean of your sins.
Come see us... Dad's Chevy
Our Video
God bless you! Michael..
