1 members (Ole49GMC),
109
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57018 02/28/2006 6:16 PM | Joined: Oct 2005 Posts: 8 Junior Member | | Junior Member Joined: Oct 2005 Posts: 8 | I have to rebuild the front end on my 1961 1-ton. I looked in the manual to find what parts are the same on the 1-ton to the 1/2 and 3/4 ton. I found all the info I needed execpt the ball joints. They are listed in repair manual as spherical joints but the are not in the parts list book as that. all I could find was king pins listed. I need help reading this book. | | |
#57019 03/01/2006 1:25 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy slowgo61, the upper ball joint P/N is 3769360 the lower ball joint P/N is 3789788 hope this helps. | | |
#57020 03/01/2006 6:19 PM | Joined: Oct 2005 Posts: 8 Junior Member | | Junior Member Joined: Oct 2005 Posts: 8 | How did you find this info. are these specific to the 1-ton? | | |
#57021 03/02/2006 12:53 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy slowgo61, I looked it up, and yes their for the 1 ton | | |
#57022 03/17/2006 1:27 AM | Joined: Apr 2002 Posts: 7 Junior Member | | Junior Member Joined: Apr 2002 Posts: 7 | are these p/n's for the dana 44 1 ton front end? | | |
#57023 03/17/2006 1:39 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy snowman, I don't recall anyone saying this was a four wheel drive, if they did I missed it, and the info I provided is for a two wheel drive truck, sorry. | | |
