Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
9 members (ndkid275, Gone, baldeagle, RaNfLaS, JW51, Shaffer's1950, Donf, crenwelge, 1 invisible), 44 guests, and 3 robots.
Topics128,005
Posts1,055,253
Members48,418
#569828 08/30/2009 10:03 PM
Can someone remind me where to go to find the ID info for my engine? Thank you, Scott (getting old!)
1954 Chevrolet 4400 1.5-Ton Dump Truck
1946 Chevy 1.5-Ton Dump Truck
1944 Chevrolet 1.5 Ton Dump Truck
1955 4400 Dump Truck
1951 2 Ton Stake Body
Scott54 #569830 08/30/2009 10:08 PM
There's 2 main places. 1 is the machined surface just behind the distributor mounting. The stamped number there will have the plant code and original application code. The other place is by the RF motor mount. That will have the block casting number, which will tell what block it is ad what years/applications it was used in. In addition, just above the starter is the block casting date, which will be reasonably close to the model year that the engine was assembled and used.
Bill Burmeister
