| | | Forums66 Topics128,009 Posts1,055,291 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 66 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 66 | Can someone remind me where to go to find the ID info for my engine? Thank you, Scott (getting old!) | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There's 2 main places. 1 is the machined surface just behind the distributor mounting. The stamped number there will have the plant code and original application code. The other place is by the RF motor mount. That will have the block casting number, which will tell what block it is ad what years/applications it was used in. In addition, just above the starter is the block casting date, which will be reasonably close to the model year that the engine was assembled and used.
Bill Burmeister | | |
