1 members (Otto Skorzeny), 127 guests, and 4 robots.
Topics128,089
Posts1,056,442
Members48,443
Apprentice
Apprentice
Hey guys-
In my 53 3100 I'll be running a '56 235 with proper after-market short-shaft 235 water pump, the big 5-blade (car) fan, and the original radiator. The radiator has no leaks and has never been repaired, and I would really like to keep it that way. Given that I am not planning on overworking the truck and have the right pump and big fan, I am tempted to order the zero-pound radiator cap, but I know running with pressure lowers the boiling point and makes the system more effective. Seems the 4lb, or 6-7lb might be closer to what this '56 235 used originally. Do you think it matters in terms of radiator longevity? Also, I do plan on drilling the hole in the thermostat, and wondering if running a 160 degree thermostat might be better if I did go with the zero-pound cap. Any opinions?
Riding in the Passing Lane
I would use a 4 lb. cap & 180 therm. If a radiator can't stand 4lb. it's time for a repair or replacement.
1972 Chevy c10 Cheyenne Super
what wrench sez - the 56 would have had a 7#, but the earlier trucks used 4# and your rad should take it - also, running the engine warmer is better than too cool, go 180, shouldn't be a problem
Each 1 lb. of pressure raises the boiling point by 3 degrees F., so a 4 lb. cap will add 12 degrees to the boiling point- - - -224 degrees at sea level. If the radiator is clean, and you've got an efficient fan, that gives you 44 degrees of leeway between thermostat opening and boil-over with a 180 degree stat. Unless you're operating on an extremely hot day, or working the engine hard, that should be plenty of operating range. The 7-lb. cap would add 21 degrees to the boiling point, but it might be a bit hard on the radiator.
Apprentice
Apprentice
Thanks guys for the help. Sounds like 4# and 180F is the way to go. Thanks again, -W
