0 members (),
191
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 31 Apprentice | | Apprentice Joined: Apr 2006 Posts: 31 | Hey guys- In my 53 3100 I'll be running a '56 235 with proper after-market short-shaft 235 water pump, the big 5-blade (car) fan, and the original radiator. The radiator has no leaks and has never been repaired, and I would really like to keep it that way. Given that I am not planning on overworking the truck and have the right pump and big fan, I am tempted to order the zero-pound radiator cap, but I know running with pressure lowers the boiling point and makes the system more effective. Seems the 4lb, or 6-7lb might be closer to what this '56 235 used originally. Do you think it matters in terms of radiator longevity? Also, I do plan on drilling the hole in the thermostat, and wondering if running a 160 degree thermostat might be better if I did go with the zero-pound cap. Any opinions? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I would use a 4 lb. cap & 180 therm. If a radiator can't stand 4lb. it's time for a repair or replacement. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what wrench sez - the 56 would have had a 7#, but the earlier trucks used 4# and your rad should take it - also, running the engine warmer is better than too cool, go 180, shouldn't be a problem
Bill | | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | Each 1 lb. of pressure raises the boiling point by 3 degrees F., so a 4 lb. cap will add 12 degrees to the boiling point- - - -224 degrees at sea level. If the radiator is clean, and you've got an efficient fan, that gives you 44 degrees of leeway between thermostat opening and boil-over with a 180 degree stat. Unless you're operating on an extremely hot day, or working the engine hard, that should be plenty of operating range. The 7-lb. cap would add 21 degrees to the boiling point, but it might be a bit hard on the radiator. Jerry
| | | | | Joined: Apr 2006 Posts: 31 Apprentice | | Apprentice Joined: Apr 2006 Posts: 31 | Thanks guys for the help. Sounds like 4# and 180F is the way to go. Thanks again, -W | | |
