| | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 48 | Did a compression check before giving the 350 a complete tune up. Compression was good and surprisingly even, average of 130 psi.
Now the engine runs well, so I need to sort out the fan situation and brakes/hubs.
The fan sits about 5" away from the radiator, probably too far for Nevada heat in traffic. I would like to avoid an electric fan, and doubt that an extended spacer is good for water-pump life. Is there a fan shroud that fits well to overcome this?
I just bought a set of "standard" 8 lug wheel hubs to replace my dual wheel hubs. I was surprised to see they use ball bearings, is there an interchange for taper bearings?
What is the big obstacle to putting 8 lug disc brakes on the original beam axle? Reading post here it appears no one makes a kit, I have a few machine tools (CNC mill and lathe, etc.) and welding equipment. Is there a reason it is truly impractical, or just something no one is doing?
Once these items are sorted out the rest of it should be "easy", right? 1957 Chevy 3600At these prices I want my gas 100 octane, leaded, and my windshield washed! | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Richard - They do make a fan shroud for these trucks. I have seen them on eBay - but have never bought one myself or I'd give you a link. This will help with your airflow.
As for the brakes - You need to hold out for other big bolters - they I'm sure can help on this. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | True, no ready made kit for the 3/4 and 1 tons. You might do a search, I seem to recall that someone did cross over the bearings to the taper style. There are also a couple of threads about doing a disk conversion using various rotors and calipers. A suggestion I'll make on that would be to look at the '01-current Silverado 2500HD/3500. They run a beefy disk with a dual piston caliper.All you would have to do is fab the caliper to spindle mounting bracket. I'm thinking about doing something similar using 1/2 ton parts should i ever swap my '55 over to disk brakes.
Bill Burmeister | | |
