1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#569425 08/29/2009 3:12 PM
Apprentice
Apprentice
Does anyone know of a source for an under cab tank for a '48.
I need a new tank and would really like to put it back in the opriginal position.
Thanks Richard
Life is simpler if you plow around the stump.
50Deluxe #569432 08/29/2009 3:43 PM
I don't think you want it under the cab. It'll scrape on the ground. dang
I don't know if any of the major vendors carry the original under bed tanks, but perhaps Bob Adler can provide one. He's got a field full of AD trucks, and I think there are a few 47's and 48's there. He ain't cheap, though, and I don't know if a used tank can be shipped, but it's worth a try. Here's a link to his website: Adler's Antique Autos
Adler's is in Stephentown, NY, by the way.
Good luck!
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Tom R #569435 08/29/2009 3:47 PM
Leo Offline
Moderator
Moderator
Those tanks were the same as the panels and suburbans, which had the same tank throughout the AD series. Mine is on the right side just ahead of the rear axle, between the frame members.
Leo #569444 08/29/2009 4:14 PM
If you find a used tank, the 54/55 panel-body tank is slightly different from the earlier tanks. It would work for you, but it has different hangers, and different fuel/sender hook ups.
Also, if you find a used tank, be sure to obtain any of the parts needed to hang the tank.
JIM CARTER HAS THEM and he's in Missouri!
The tanks are very similar to the suburban tanks and the filler neck is unique to the pick-ups. The tanks will interchange using the same straps and changing the filler necks (would be some work though)
GMONIZ #569709 08/30/2009 2:25 PM
Apprentice
Apprentice
Thanks guys.
It's good to know they are available. I had looked but not found them.
I'm not sure this is what I will use but it is an option. Final plans are still a ways out.
I don't like the tank behind the seat and don't care for the fill cap in the bed floor.
