| | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | I have a 1966 with a 250 and I would like to put an aluminum valve cover on it. I can't find any that have the holes for the pvc valve and the hole for the hose that goes to the air filter has anyone bought an aluminum valve cover for a 6 cyl. | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Pontiac had an aluminium valve cover on its 6 cyl. firebird engine but I don't know the engine size.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Most likely, you'll have to put the holes in it yourself. That's very common when dealing with aftermarket aluminum rocker covers.
Bill Burmeister | | |
