7 members (Wayne67vert, baldeagle, 74cheyennesuper, NorCal52Suburban, Ponchogl, Peggy M, NJC), 60 guests, and 4 robots.
Topics128,014
Posts1,055,328
Members48,419
#569448 08/29/2009 4:26 PM
Have a 1954 261 in my 1953 3/4 T. Chev with a T5 transmission and 390 rear gears, 31" tires. Now doing 58 m.p.h. at 2200 RPM.
Am thinking about switching out to another T5 that is 25% overdrive. Live in CO foothills, so up and down lots of mountain roads. Am I messing up to go to higher overdrive with current setup?
Thanks--TK261
what's the purpose? you want to do more than 60 on mountain roads in a 53 3/4T? seems putting the effort into better brakes might be more productive
Nope--just thought I might be able to improve a bit on highway speed, but I still have to get up and down the hill for daily commute. Didn't know how much I might lose on the tradeoff--? But you make a darn good point on the brakes!
Thanks for the input--TK261
I'm running the 4:11 gears in my 53 3/4 ton 235 motor and I can keep up with traffic if I want. You should be sailing with the 3:70s. BTW what did those gears come out of???
Jim
1946 1/2-Ton Chevy
up and down hills has nothing to do with OD, if it's much of a hill you'll be downshifting or lugging the poor thing .... I'd say go with the ratio you already have and move on to other improvements if you use it regular at highway speeds - 2500 rpm for a good 261 shouldn't be a problem but 65mph with 55 year old steering and braking technology could easily be, not to mention the stress on wheel/axle bearings, these trucks weren't designed with modern freeways in mind
Your choices for a General Motors overdrive gear are .63, .68, .72, .73, .78 and .86, but that is ALL of the GM choices. Some of those are cars with the tail shaft shifter. If you already have the .63 or .68, I don't know how you could do any better and if you have the .72 or .73, the difference between .68 and .72 or .73 is going to be not that noticeable. If by chance you have the .78 or .86 overdrive, than you might be able to help your self by dropping to the .63. That is a big drop and I can't see how over drive (5th gear) can be much good in the hills. I would think it is more of a a flat land, straight roads gear.
O.K.--did some more checking--I have 4.11 rear gears, .86 OD--but considering all posts, think I'll stick with what I've got. Time (and $'s) better spent on other improvements as suggested.
Thanks guys.
