| | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 28 Apprentice | | Apprentice Joined: Mar 2007 Posts: 28 | Does anyone know of a source for an under cab tank for a '48. I need a new tank and would really like to put it back in the opriginal position.
Thanks Richard
Life is simpler if you plow around the stump.
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I don't think you want it under the cab. It'll scrape on the ground.  I don't know if any of the major vendors carry the original under bed tanks, but perhaps Bob Adler can provide one. He's got a field full of AD trucks, and I think there are a few 47's and 48's there. He ain't cheap, though, and I don't know if a used tank can be shipped, but it's worth a try. Here's a link to his website: Adler's Antique AutosAdler's is in Stephentown, NY, by the way. Good luck!
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Those tanks were the same as the panels and suburbans, which had the same tank throughout the AD series. Mine is on the right side just ahead of the rear axle, between the frame members. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you find a used tank, the 54/55 panel-body tank is slightly different from the earlier tanks. It would work for you, but it has different hangers, and different fuel/sender hook ups.
Also, if you find a used tank, be sure to obtain any of the parts needed to hang the tank.
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | JIM CARTER HAS THEM and he's in Missouri! The tanks are very similar to the suburban tanks and the filler neck is unique to the pick-ups. The tanks will interchange using the same straps and changing the filler necks (would be some work though) | | | | | Joined: Mar 2007 Posts: 28 Apprentice | | Apprentice Joined: Mar 2007 Posts: 28 | Thanks guys. It's good to know they are available. I had looked but not found them.
I'm not sure this is what I will use but it is an option. Final plans are still a ways out.
I don't like the tank behind the seat and don't care for the fill cap in the bed floor.
