| | | Forums66 Topics128,014 Posts1,055,325 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 99 | Are there any differences between a 55-59 long step-side bed and a 60-66 long step-side? If I find a 60-66 long step-side what modifications would need to be done to bolt it onto my 1955 frame?
Neil 1955 Chevy 3200
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The basic box itself is the same, but there are some differences in the cross sills and the bed boards. In the case of the '55-mid-'57s 1/2 and 3/4 ton longbeds, there is also a 6" difference in length, with the earlier bed being shorter.
Bill Burmeister | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | Neil, there are a lot of differences, some subtle and some significant. Length is probably the biggest concern with this swap, the 60's beds being a lot longer than your 55 bed. Of course there are two different bed designs within the 60-66 series and it depends whether you have the 60-62 or 63-66 bed. We have detailed the major changes in our "Bed side interchangeability" article under http://www.mar-k.com/installation_hints.html. Scroll down to the Bedside interchangeability for long beds for more information. Mar-Ktech | | |
