| | | Forums66 Topics128,082 Posts1,055,964 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 10 New Guy | | New Guy Joined: Aug 2008 Posts: 10 | Hi Guys, my engine starts to hesitate like its running out of gas until you mash down on the pedal then it picks up with good power until you let off the gas then it starts all over .The carb bowl is full of gas the fuel pump is new the coil is new ,just not sure if its fuel or electrical .Thanks | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | Look for vacuum leaks. Also, try setting the idle mixture for best idle, and set the idle speed up a little. The good power with acceleration eliminates many suspects, including most electrical troubles.
Harvester | | | | | Joined: Aug 2008 Posts: 10 New Guy | | New Guy Joined: Aug 2008 Posts: 10 | Thanks Wrench Fetcher,I'll try that first thing tomorrow,I hope its something that simple, it does'nt do it all the time,Drove it 100 miles round trip to a car show this past Saturday and everything was great,not a problem . Drove about 3 miles today and it started doing it. Thanks again, Jim. | | | | | Joined: Aug 2008 Posts: 10 New Guy | | New Guy Joined: Aug 2008 Posts: 10 | I tried to make the carb. more rich and raised the idle but its running terrible ,didnt help , I took the rochester apart but cant find anything obivious wrong , maybe it just needs a good soaking, any suggestions | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | can't find vacuum leaks by lookin inside the carb
Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Since you have it apart already, put a new gasket set in it. Replace the base to manifold gasket, too. Might also want to check the carb isolator for cracks. Other places to look for leaks are the manifold to head gaskets and the wiper vacuum supply hose, if equipped. Another thing to check, just judging from the description of what it's doing, check the timing. You may need to advance it a bit.
Bill Burmeister | | | | | Joined: Aug 2008 Posts: 10 New Guy | | New Guy Joined: Aug 2008 Posts: 10 | Sorry I forgot to mention I didnt find a vacuum leak from the vacuum advance to the carb or the wiper hose.I'll replace the gaskets in the carb tomorrow .why does it smooth out when I add choke after its warmed up. Thanks for the help , Jim | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That does sem to indicate vacuum leak. May need to replace the intake manifold gaskets.
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | as longbox sez, if using the choke smooths it out you've got a leak some place
Bill | | | | | Joined: Aug 2008 Posts: 10 New Guy | | New Guy Joined: Aug 2008 Posts: 10 | Whats the best way to find a vacuum leak | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Sounds like vacuum to me. But don't rule out point gap, timing, and or possible low voltage problems. The low voltage problem will feal like fuel starvation. This condition could be caused by an improperly adjusted voltage regulator along with a weak battery. It would correct itself when you accelerate due to the charging system working better at a higher engine RPM.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
