7 members (52Carl, joe apple, Otto Skorzeny, 55shaker, Gray_Ghost, Hush, JW51), 147 guests, and 2 robots.
Topics128,108
Posts1,056,238
Members48,437
#569027 08/28/2009 12:40 AM
I have a all original 1946 pickup and the wiring in it is horrible. I want to get an original looking harness for it. does anyone know of any that look factory ? I looked in jim carter and its only 150.$ I just wanna know it looks original. Thanks
actually the "original looking" harness at JC is like $500 ELW109, it's the cloth covered wire as yours would have been - the cheaper one is PVC coated wire and PVC tape wrapped .... original appearing to someone who doesn't know better, but not to most of us grin
there are other places that will have the same cloth covered version, but they're all pretty spendy
Ex Hall Monitor
Ex Hall Monitor
As Bill said, the cloth cover harnesses are expensive. I used the harness from YNZ on my 38. My harness was the best of both worlds. It has the vinyl insulation with the cloth over that so as the cloth ages & starts to go away, the modern insulation is still there to prevent shorts.
I used a co. called Lectric Limited for a 54 vette I was restoring. The harness had cloth covering and correct wiring connectors, it also came with a laminated wiring schematic (2ft x 3ft.) that now hangs on my garage wall. The web address is www.classiccarelectrical.com .
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
Riding in the Passing Lane
1972 Chevy c10 Cheyenne Super
Wow thanks for all the help
