| | | Forums66 Topics128,022 Posts1,055,386 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 75 | A friend of mine talked me into just getting the truck running, he has a machine shop he uses all the time and gets great prices he told me to pull everything off the block and he will take it and have it dipped and machined for a few hundred or so, So I am having problems figuring out how to get the headers off he will be here to get it after he gets off work any help would be appreciated, also the exhaust manifold bolts are stuck also any ideas or that? | | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | Impact wrench?
Breaker bar?
Bryan 1954 3104 235 "AD" L-6 3-on-the tree
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | You could try PB Blaster penetrant avaiable at your parts store. Works quick to penetrate, but still might take muscle to fre up the bolts.Sometimes heat from a torch helps too.
Drew
