1 members (Hotrod Lincoln), 61 guests, and 2 robots.
Topics128,049
Posts1,055,740
#568764 08/27/2009 3:04 AM
I've done several frame swaps with the 78-79 monticarlo/malibu chassis and I wonder if anyone has photos of the rear section on how it looks before the floor is put back in on a Burb?
Sully
sullys garage #568788 08/27/2009 3:50 AM
Y
Y Offline
Check out fellow bolter ZooKeeper and his burb "Large Marge". He's done a great job of documenting his work with pictures. Maybe that will help?
Yakimabowtie #568792 08/27/2009 3:59 AM
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
It's ZooKeeper & when you click on the link below it'll take you to my old screen name's webshots page. But I did mine w/a S10 frame & from what I have seen the coil over set up eats up wayyyyyy too much room in the rear then a leaf spring set up. I raised my floor up in the rear about 3 inches because I had a stainless steel box made for a trunk to be hidden under the floor...Joe
#569346 08/29/2009 2:44 AM
Great Will do.
Sully
