| | | Forums66 Topics128,052 Posts1,055,725 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 95 | I've done several frame swaps with the 78-79 monticarlo/malibu chassis and I wonder if anyone has photos of the rear section on how it looks before the floor is put back in on a Burb?
Sully
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Check out fellow bolter ZooKeeper and his burb "Large Marge". He's done a great job of documenting his work with pictures. Maybe that will help?
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | It's ZooKeeper & when you click on the link below it'll take you to my old screen name's webshots page. But I did mine w/a S10 frame & from what I have seen the coil over set up eats up wayyyyyy too much room in the rear then a leaf spring set up. I raised my floor up in the rear about 3 inches because I had a stainless steel box made for a trunk to be hidden under the floor...Joe | | | | | Joined: Feb 2009 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 95 |
Sully
