1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 5 New Guy | | New Guy Joined: Jul 2009 Posts: 5 | Does anyone have any hints, advice, warnings, etc. for putting 350 small block with 700r4 trans into '61 Apache short bed fleetside where 235 6 cyl and manual trans used to be? We have the frame off so there is plenty of room to work. Right now we are planning on keeping the original suspension and rear end. All help greatly appreciated! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the truck could optionally have had a V8, your assembly manual [you do have one?  ] will heve most everything you need to know other than some adjustments you'll need to make for the later trans - will likely need to add a trans crossmember, and correct side mounts for the 350 Bill | | |
