| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I installed an unused YF964S in my 55.1 235. It slows on the hills more than I think it should. If I pull out the choke about 3/8 inch, it does fine, or more like I would expect. Also, when I drove a choke vehicle in the past, I would be able to push the choke in after about 2 blocks. Now, I have to go for about 12 minutes and it still balks at the stop signs.
Is this an orifice size problem or some other adjustment I didn't do properly when I installed this clean new carb. Thanks-Scott
55 1st Chev.
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | If I'm not mistaken, a 964S should be for a 216. | | | | | Joined: Apr 2009 Posts: 1 New Guy | | New Guy Joined: Apr 2009 Posts: 1 | The 964s is for the 216 ( it should be a carter) | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sounds like it is running lean. Check the float level. You might try raiseing it a little above specs. If that is not it you will need a larger main jet or possibly adjust the metering rod. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Thanks for the tips. I will give it a try.
Scott
55 1st Chev.
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | As previously noted by others the 964s was designed for the 216; not the 235.
This is a classic example of why more than one carburetor is produced; and why carburetor selection is so important.
The main venturi in the 964s is 1 1/4 inch. The main venturi in the 967s (for use on a 235) is 1 5/16 inch. Does this 1/16 of an inch really make that much difference? YOU BET!
Do the math:
The overall venturi area of the 964s is 1.227 inch while the overall venturi area of the 967s is 1.353 inch. So the overall venturi area is 10.2 percent greater on the 967s. Now factor in that the booster is the same on both so the percentage increase is probably more like 15 percent.
A 235 is a little more than 8 percent larger in displacement than a 216.
This carb should run well at idle and very low RPM (giving increased low end efficiency due to higher air velocity) but will run out of steam prior to the normal maximum RPM of the engine; and produce significantly less power under load (slowing down on hills).
This was a concept developed in the 1930's for use on taxis. Run a smaller venturi for a vehicle that would normally run 25~35 MPH maximum, but increase the fuel economy at the lower speeds.
You are running out of air!
Jon.
Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Jon, I have a YF964S as a spare carb and wrongly assumed that is what I had on my 235 (bored 0.030 over by the way). I checked my carb on the truck and it is a YF2100S (manual choke). Sorry about my mistaken identity. I still use the old oil bath air filter. I have the 9797 fuel pump with the vac pump piggy backed to help feed the wiper motor vac on the hills. I removed the "draft tube" and put in a pcv between the draft tube port and the intake manifold. Maybe I am loosing too much vac to the pcv line.
Is the YF2100S the wrong carb for my bored 235?
Might it have the wrong orifice size?
Thanks - Scott
55 1st Chev.
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | The 2100s is the proper carb for the 235.
As Wrenchbender said, you may have an incorrect float level, or incorrect main metering jet.
Loss of power is also a symptom of using E-10 ethanol (regardless of what our government would have you believe).
Check the specs on both the metering rod and main metering jet. Pay no attention to the numbers (people drill out jets, and emery metering rods). Use a micrometer and get the actual specs.
At the same time, check the float setting.
And, check with the manager of your local station to see if you are burning ethanol. There are calibration changes you can make.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | And one other thought: running high octane fuel in an engine designed for regular can show these symptoms. What octane fuel are you burning?
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Jon, Thanks for the tips. I use only Shell regular unleaded 87 octane gas in the truck. The pump says it MAY contain UP TO 10% ethanol. I will have to ask to find out the actual %. I will have to explore the jet size and the other suggestions after I get the ethanol percentage. Thanks again!
Scott
55 1st Chev.
| | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I just called the gas station and they said that the current batch has 10% ethanol. - Scott
55 1st Chev.
