| | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | I trying to figure out what color to paint the interior of my '53 chevy and found an old thread that said rustoleum 7272 (dark bronze metallic) is a good color.
All the pictures in the older threads are dead, if anyone has one please post it.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | Hmm, after re-reading my post I don't think I was very clear. I am looking for a picture of a cab that has been painted with Rustoleum 7272. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well Fern, if you're not looking for the correct color then why don't ya just pickup a can of Rustoleum 7272. $3.99 at the Menards or any big box store, mask of the dash and shoot it to see whether you like it or not. The number that I gave you is the PPG off set number for the original Ditzler color. Most PPG paint dealers can mix that up and put it into a rattle can or if you would rather, just grab a pint and a Preval sprayer and shoot a small section. The paint you choose all depends on what your goal is, be it preservation or customization. DG
| | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | Hmmm, I forgot about those Preval sprayers. I am new to paint so please forgive my dumb questions. PPG's website shows a ton of different types of paint, which kind should I ask for? Also, what other surface prep besides striping down to bare metal should I do? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | For the interior I use PPG Deltron DBU/DBI 31104. Just spray the base coat, no clearcoat and the sheen will be just about perfect for the interior. I use it on the bare metal as the original paint was applied, no base just clean it well and use a conversion coating on it. Denny G
| | | | | Joined: Dec 2008 Posts: 28 New Guy | | New Guy Joined: Dec 2008 Posts: 28 | I'm also new. What is a conversion coat? | | |
