8 members (Robert Crandall, kades51, Hotrod Lincoln, jay d, Hanks custodian, Rusty Heaps, Uncles51, 1 invisible), 124 guests, and 2 robots.
Topics128,041
Posts1,055,480
Members48,424
#567793 08/23/2009 11:59 PM
Hello,
The truck is a 51 3100, only had it a few months. Was washing it today and noticed that on the passenger side in front of the door there are louvers. Not there on the drivers side. Just wondering why that would be and what purpose do they serve.
Thanks!
Chris
kenneycj #567799 08/24/2009 12:25 AM
If you have a deluxe heater it pulls fresh air into the cab through them. If not they do nothing.
Cletis #567820 08/24/2009 1:38 AM
Often wondered about that Cletis, I do have a deluxe heater but with out one is that hole simply covered over with a plate? I would think that it would be a source for cold air in the winter time. And the rain thing, how do you deal with the rain that blows in to the opening even if you have the heater installed???
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Denny Graham #567835 08/24/2009 2:24 AM
Denny,
All 47-55 trucks without a heater from the factory came with a cover (and seal/gasket) over the hole on the passenger side. By 1949, all trucks came from the factory without a heater (and there was no factory RPO for a heater). That plate was, of course, still needed when the more common recirculating heater was installed. I think I have a couple of those cover plates, if you want me to post a photo.
Tim
tclederman #567861 08/24/2009 3:33 AM
yeah Tim if ya got one handy I'd like to see that since I've on had exposure to a few with the deluxe heaters. Do I understand you to say that from '49 on all of the heaters were dealer installed accessorys? I have a friend ritht now who I'm helping with a '50 that had a recirculating heater but he dosn't have a cover over the opening. I'm sure he will need it before the bum weather sets in this year. Never noticed if the vendors sell them, seems logical that they would.
Denny G
Sandwich, IL
Denny Graham #567940 08/24/2009 1:36 PM
Thanks guys for the info.
Chris
Denny Graham #567944 08/24/2009 1:49 PM
Denny Graham
Sandwich, IL
Denny, There is a drain hole in the bottom of the cowl for the water to drain. If it is not plugged up with dirt.
Also I think the cover that is being refered to could be described as a Fresh Air heater delete plate.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
31,32,33 #567960 08/24/2009 3:11 PM
I think that the cover for the 1947-1955 lower-right, inner-cowl opening is: COVER, right inner panel, part number 3684403.
Mine measures 11 3/4 by 6 7/8:
Here are two photos of the cover - a merged image of a flash & a non-flash photo.
The cover is attached with six 1/4"x 1/2" clutch-head machine screws (and "star" lock washers) into captive nuts in the inner cowl.
Tim
tclederman #568153 08/25/2009 3:37 AM
Makes sense, Thanks Tim, just what I needed to fab one. That looks simple enough to make, I'll whip one up for my buddy.
I had my deluxe heater out earlier this summer and the back clutch head screws are about impossible to get in or out, so they are hex head bolts now, the front ones that show are still clutch heads. I think I have the pictures of the kick panel with the heater out, I’ll see if any show the drain holes.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
