7 members (55shaker, MickeyP, KCMongo, Otto Skorzeny, Wally / Montana, Gdads51, Nick in Manitou), 106 guests, and 0 robots.
Topics128,050
Posts1,055,704
#567604 08/23/2009 1:37 AM
Alrighty, quick question about engines that have remained idle a while. I pulled the spark plugs out of a '69 C/50 that had stayed at rest for quite a while, and poured kerosene down the cylinders. All but one cylinder drained out, so I assume that is the stuck cylinder ... Now, on an inline six, the chances are pretty good another intake is open while this one is, so why is it just this piston is stuck? Just a random question spun by boredom.
1959 Chevrolet 3100 Stepside Apache
"Ignorance is bliss. Here's a history book."
Luck of the draw?
Pete
if a piston is stuck it didn't have to rust all the way around. i have seen a lot that did this. also it might be the only one that has good compression. haha seriously, it might have a crack that let in antifreeze. is it #1?
I am with Pete on this, luck of the draw! It just happen to be open where bugs, mice, or water got in.
Try pouring a can of Marvel Mystery Oil down the plug hole. It has worked for me on engines that have set as long 20 years. Let it sit for a week or two and try to break it loose by hand if possible. If it is just frozen piston or rings it should work. If the bearings are froze you may have to disasemble.
Good luck.
