5 members (Randy Baumann, TexasJim50, 52Carl, dt235sd, 1955 1 Series), 77 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#56750 02/20/2006 2:01 AM
Is the 228 gmc a babbit bairing motor (1950)
#56751 02/20/2006 3:31 AM
No.
1954 GMC De Luxe COE
#56752 02/20/2006 5:54 PM
I'm not a older GMC guy but it seems to me that I've heard that all the Jimmies were insert bearing engines. Can one of the real GMC members confirm that?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#56753 02/20/2006 8:45 PM
don't quote me, but some time back in the late 30's, the gmc's used full pressure oiling/bearings. i think chevy used the babbit system up until the mid 50's.
my 53 gmc 100-22, 228 has the full pressure system.
tony
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
#56754 02/21/2006 10:47 PM
GMC went to full-pressure oiling and insert bearings in the late 30s when the 228-302 engines were designed. They also used higher nickel-content iron in the blocks. Just look at GMC gauges - the have 0-60 psi readings, rather than 0-30 psi.
#56755 02/22/2006 12:34 PM
The 1936 GMC 213 engine (Olds inline 6) was a full pressure engine. My oil pressure gauge goes from 0 to 80 psi, usually runs in 25 to 36 psi range.
1936 GMC T-14 1/2-Ton Pickup
