0 members (),
186
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 7 New Guy | | New Guy Joined: Sep 2005 Posts: 7 | Hello all, Thnaks so much for help in the past. My 1953 pickup heats up Really Fast. 180 F. quickly. Seems too hot. Doesn't boil over. New radiator core, water pumps seems fine, Manifold haet control valve good. No leaks
Am I missing something ?
Thnaks again, Joe
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sounds fine to me, not too hot, just right, likely you have a 180* thermostat, which is appropriate
Bill | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | This time of the year it don't take long for the water to heat up and if its holding 180 your system must be in good condition. | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | You will appreciate the fast heat in the winter - it should heat up fast because the thermostat is closed - preventing water from flowing until it reaches it's correct temp. In your case it sounds like 180*. If it doesn't blow over & doesn't go above 200* your fine!
