| | | Forums66 Topics128,259 Posts1,058,298 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 1 New Guy | | New Guy Joined: Aug 2009 Posts: 1 | I just bought a 1961 Chevy c10 with no vin number on the windshield pillar by the left door jam and can't find one on the top of the frame on the left front side. Any suggestions of another place to look for a VIN or is that it? | | | | | Joined: Jan 2007 Posts: 118 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 118 | the manuel only shows it on the left hinge pillar, thats where mine is | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | That would be about it, unfortunately. I think I remember it might be on a second place on the frame, but I'm not 100% sure. It seems to me like I saw it on a '63 on the side of the left frame rail about halfway back and then again further forward on top of the left frame rail, where you mention. It may not hurt to check it again anyway.
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: Mar 2006 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 114 | On the 1961, the serial number is stamped into the top of the left frame rail in two spots.
First location is in the engine compartment. (With the hood open)Look on top of frame rail area located between the driver front wheel and the exhaust manifold.
Second location is on the same frame rail located under the cab. It would be about directly below the gas tank area if you removed the cab.
The "serial number" stamped into the frame is only part of the total VIN number. The last seven digits of VIN i.e. K100001.
