4 members (Wayne67vert, MickeyP, Otto Skorzeny, Bill Hanlon), 176 guests, and 0 robots.
Topics128,106
Posts1,056,213
Members48,436
#567145 08/21/2009 1:29 AM
I just bought a 1961 Chevy c10 with no vin number on the windshield pillar by the left door jam and can't find one on the top of the frame on the left front side. Any suggestions of another place to look for a VIN or is that it?
the manuel only shows it on the left hinge pillar, thats where mine is
That would be about it, unfortunately. I think I remember it might be on a second place on the frame, but I'm not 100% sure. It seems to me like I saw it on a '63 on the side of the left frame rail about halfway back and then again further forward on top of the left frame rail, where you mention. It may not hurt to check it again anyway.
1963 Chevy C20 Longbed Stepside
1978 Chevy K30 Custom Deluxe
On the 1961, the serial number is stamped into the top of the left frame rail in two spots.
First location is in the engine compartment. (With the hood open)Look on top of frame rail area located between the driver front wheel and the exhaust manifold.
Second location is on the same frame rail located under the cab. It would be about directly below the gas tank area if you removed the cab.
The "serial number" stamped into the frame is only part of the total VIN number. The last seven digits of VIN i.e. K100001.
Your wife called & said
"buy whatever you want"!
1961 Chevy Apache 10 Restoration Photo Album
in the Gallery ...
My 1961 Chevy Custom Apache 10 SWB
