7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen), 117 guests, and 1 robot.
Topics128,081
Posts1,056,068
Members48,433
#567124 08/21/2009 12:50 AM
LHG
Offline
Hello all, Thnaks so much for help in the past.
My 1953 pickup heats up Really
Fast. 180 F. quickly.
Seems too hot. Doesn't boil over.
New radiator core, water pumps seems fine,
Manifold haet control valve good. No leaks
Am I missing something ?
Thnaks again,
Joe
sounds fine to me, not too hot, just right, likely you have a 180* thermostat, which is appropriate
Y
Y Offline
This time of the year it don't take long for the water to heat up and if its holding 180 your system must be in good condition.
You will appreciate the fast heat in the winter - it should heat up fast because the thermostat is closed - preventing water from flowing until it reaches it's correct temp. In your case it sounds like 180*. If it doesn't blow over & doesn't go above 200* your fine!
1958 Chevy Apache 3200
bone stock 235
53k miles
3 on the tree
