4 members (TooMany2count, frogfarmer, moparguy, 1 invisible), 55 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
hi i was just wondering how the stock heater in my '49 should operate. whenever i turn it on the first speed, I hear a low hum, and nothing else. but the second and third make it rumble and rattle, which worries me. is this supposed to happen. or is something wrong?
thanks,
Trevor
grin definitely somethings wrong .... sounds like the motor is shot or bearings rotten - the hum will be the motor trying to turn, may burn some wires if you let it go long - the rattle may be a loose fan on the shaft or the bad bearings .... you need to get in there and take it apart, clean it up good [might be fulla rat nest], check the motor, rebuild it if necessary
That's right, since you are in the Vermont I wouldn't put it off to long.
alright, I'll get on it as soon as possible.
thanks
Moderated by  ndkid275, Phak1
