Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (homer52, Otto Skorzeny, TooMany2count), 152 guests, and 5 robots.
Topics128,277
Posts1,058,441
Members48,490
#56667 02/18/2006 2:12 AM
Can some one explain what the difference is???? I have this sm465 available and was wondering, about the differences..
49' Chev, 3808 platform
#56668 02/18/2006 4:25 AM
One web site that has a lot of good info. on transmissions is,
http://www.novak-adapt.com/knowledge/transmission_gateway.htm
Adam
Adam
stovebolt2355
http://www.stovebolt2355.com
#56669 02/18/2006 4:34 AM
Thanks Adam, just what I needed....
#56670 02/18/2006 4:36 AM
V
V Offline
What were you wondering?
Both transmissions have a good reputation, they were both used for long periods of time in lots of trucks carrying heavy loads, etc. The sm465 is capable of handling more torque than the 420.
The sm465 has a larger input bearing retainer than the sm420, so it will not fit into your stock bellhousing unless it is machined out.
The sm465 may not fit your truck (the 49) because it is so much physically bigger than the sm420.
#56671 02/18/2006 5:11 AM
Actually Vaughn the curiosity was placing the trans and a 350 into something other than the 49', and lastly I just wanted to know becuz I have one with bell housing and an engine.
