5 members (Nuts&Bolts, Joe H, baldeagle, Shade Baby, dt235sd), 66 guests, and 1 robot.
Topics128,014
Posts1,055,331
Members48,419
#566426 08/19/2009 12:33 AM
1 Offline
Didnt't think this was electrical, so forgive me if i'm wrong.
Why is my antennae twice the size of a modern cars, is it the difference in radio pickup backthen or what, its almost like a CB whip!
http://s101.photobucket.com/albums/...iew&current=downsized_0818091902.jpg
3 Speed Or No Speed
1965 Chevrolet C10 Stepside
1965 Chevy C10 #566455 08/19/2009 1:56 AM
not really 'electrical', but definitely radio wink
AM reception does need more antenna, depending on station location, but the original would be 'telescopic' so that it could be extended or retracted
Flxible #566471 08/19/2009 2:22 AM
1 Offline
Yea mine extends
3 Speed Or No Speed
1965 Chevy C10 #566488 08/19/2009 2:51 AM
The higher the frequency the shorter the antenna. If it bothers you push it in some. You can tune the length for the band you listen to most. You will have to push it in an inch or so and then back away so your body isn't changing the reception. Probably not going to make a ton of difference but you can push it in some.
neilroy #566626 08/19/2009 3:08 PM
Come now, its not that bad. I have to remember to lower my antenna when I come home. I've got the 4 section one for my 1-Ton, its six feet tall when out. Helps me pull in all those great AM stations. Well, okay, I love it because I can listen to KIXI from seattle. I am going to put the same giant antenna on my Pontiac, when I get time.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #566635 08/19/2009 3:29 PM
the one on my ol 57 would pick up stations from quite a distance even down all the way, which was about half as high as the windshield
Flxible #566738 08/19/2009 9:56 PM
1 Offline
It's not a problem at all, i never use the garage, It gets great reception, and it looks kinda neat flappin all over the place, i was just curious as to why it was made to be that tall.
3 Speed Or No Speed
1965 Chevy C10 #566804 08/20/2009 1:37 AM
I have a reproduction one on my 1951 and the gain increases quite a bit as it is extended. The biggest jump seems to be when it clears the roof of the cab.
1951 1 Ton Completed
Moderated by  truckernix
