6 members (46 Texaco, Opelika Tom, ndkid275, Stan 58, RoadsScholar, Otto Skorzeny), 100 guests, and 0 robots.
Topics128,083
Posts1,055,967
Members48,430
#56641 02/17/2006 2:47 AM
I hopped in the truck this afternoon to run to NAPA for a gasket, put the transmission in reverse, and when I let out on the clutch I heard a clunk and the truck didn't go anywhere. I checked to make sure it hadn't jumped out of gear...sure enough it hadn't. All forward gears work, but reverse is dead. I drove it around the block...no grinding, crunching or other foreign noises...it just won't back up. Guess I get to rebuild it sooner than I'd hoped. Sound familiar to anybody?
Daily Driver 63 C-10 LWB Fleetside
#56642 02/17/2006 2:54 AM
Texmo,
Don't buy a cemetery plot yet. The linkage inside the T-5 is know to fizzle out quite often. smile
Stuart
#56643 02/17/2006 3:12 AM
Linkage? This is my first go around with a T-5 and I really liked it until today...
I'd been planning on rebuilding it since its a bone yard upgrade anyway.
#56644 02/17/2006 3:32 AM
Texmo,
I semi-rebuilt my son's T-5 in his S-10. The basic transmission has different tail shafts/shifter available I believe. The shifter location for the S-10 is mid-case. The similar transmission for, say a Camaro, has the shifter much farther back.
The shift mechanism is full of little nylon bushings and dainty shift forks. If you do a search, you can probably find a exploded view, and it might give you some leads.
I am far from Mr. AAMCO, but, to loose reverse with out any forewarning would indicate to me that the mechanism that engages it might have taken a dump.
This site is popular with T-5 folks, maybe one will show up with a answer.
Stuart
#56645 02/17/2006 3:39 AM
I have a "new" 230 in the garage on my engine stand right now that I've been getting ready to put in and the tranny rebuild was on the schedule when I pulled the old engine. I was going to wait until school was out so that my son and I could do the whole thing together, but it looks like it'll happen sooner than I'd planned. Maybe I'll get the chance over the next couple of weeks to pull the T-5 and see if I find any bits rattling around inside. Thanks for the tip.
