| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 24 Apprentice | | Apprentice Joined: Aug 2009 Posts: 24 | Having a'51 Chevy 3/4 ton 3600 with a '56 235 engine I thought maybe at one point somethings may not be compatible. Well, trying to trace the electrical on the wiper motor produced that dilemma. After reading in Keith Hardy's book that it was a vacuum type motor and I should be looking for a vacuum hose instead of an electrical wire, I found it alright. One inch of hose cut off right at the wiper motor. Does that mean that a '56 235 engine is not designed to feed a vacuum hose to this wiper motor? I sure would hate to have to rig some kind of rubber band with a foot pedal or attach it to a round cage with a squirrel in it. Any suggestion from the "Brotherhood of the Bolts"?
Paul B.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Look at the intake manifold,it should have a vacumn port.Run your wipers off of this port.see illistration below. intake manifold vacum port 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Aug 2009 Posts: 24 Apprentice | | Apprentice Joined: Aug 2009 Posts: 24 | Thank you bowtietim. I took a couple of pix and if you look at pix # Eng.-10 the intake manifold has a port with a plug (square head) facing out, is that it? It also has Fenton dual exhaust manifolds with each one having a buttonlike port with outer threads. Do you have any idea what are those for? Paul B http://s868.photobucket.com/ab247/goaliepab/ | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, the plug in the center of the manifold right below the carb is the vacuum wiper port
Bill | | | | | Joined: Aug 2009 Posts: 24 Apprentice | | Apprentice Joined: Aug 2009 Posts: 24 | Thank you. I'm sure this will work out better than the rubber band or squirrel.
Paul B. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | The ports on the fentons are to heat the intake manifold.Do a search on heated intake manifold,you will find plenty of information on the subject. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Aug 2009 Posts: 24 Apprentice | | Apprentice Joined: Aug 2009 Posts: 24 | Thank you very much, I will do so. Can't say enough about you "Bolters". You're second to none. Thanks again.
Paul B. | | |
