| | | Forums66 Topics128,184 Posts1,057,195 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 77 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 77 | Hi, I couldn't find this in the archives, surprisingly. The door latch on the back door of my 61 Panel truck has a little spring that moves mechanism back into open position to allow door to latch when closed. The end of the spring has rusted off. Previous owner showed me how you had to flip it back when you opened door but I'd like to fix it. It looks like easiest is to find another good latch with unrusted spring. Anyone run into this? Anyone know what I'm talking about - my terminology is pretty poor.
Thanks Pete | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | I know EXACTLY what you're talking about. It should be somewhat easy to find a donor latch. You also might try going to McMaster-Carr, and industrial supply house, and see if they've got a spring in their catalog that might just swap in. Spend some time in their online catalog... they've got EVERYTHING. Awesome place.
My problem with the rear barn doors on my '62 is that the catches are all so worn, there's no adjustment in them. That little latch you have to flip with your finger? On my truck, that jaw is worn a good 1/4-inch. The round rod on the other half of that latch is worn half way through on mine, for both the top and bottom catches. 47 years of daily driving has taken it's toll!
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Mar 2005 Posts: 189 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 189 | Pete, Send me a picture of the part you are looking for. and i will check the Suburban door pile to see if i have one. [email protected] | | |
