| | | Forums66 Topics128,087 Posts1,056,115 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 31 New Guy | | New Guy Joined: Aug 2009 Posts: 31 | Will a 38 half ton grille fit in a 37 half ton grille surround? Will the 38 hood also fit? And lastly are the headlight buckets and platforms interchangeable? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | #1: No #2: Don't know, maybe. #3: Not sure. The '37's headlight stand is removable. In '38 the car's stand is made into the core support but I don't know about the trucks. The headlight bucket itself may be interchangeable but I'm not sure. I've never seen a '37 & '38 bucket side by side.
| | | | | Joined: Feb 2000 Posts: 5,215 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,215 | Hoods, NO. Core support, NO. Headlight stands are different but might interchange. ( my '37 has '40 Chevrolet stands on it). Headlight buckets are the same.
Go to the gallery and look at a '38 then a '37. You will see the front clip is quite different.
Front fenders are the same, and cab to rear bumper is the same.
Joe | | | | | Joined: Aug 2009 Posts: 31 New Guy | | New Guy Joined: Aug 2009 Posts: 31 | thanks for the info, appreciate it
oldbald2 | | |
