8 members (Mike B, WICruiser, Youngin' Tut 59, Pete1946, Bizaircon, klhansen, LuckyLee, 1 invisible), 72 guests, and 1 robot.
Topics128,140
Posts1,056,770
Members48,454
I had to take the front sheetmetal off the front end of my 3800 panel because the flanges on the radiator support had snapped off. When I had my truck painted five years ago, the bodyshop people put the front sheetmetal back on with less than half the fasteners. As a result, the weight of the fenders eventually broke off the flanges.
I took off the front end, had the flanges welded back on, had the radiator support powdered-coated and reinstalled it.
Now I'm ready to reinstall the inner and outer fenders,along with the grill.
My question is: what is the best procedure for reassembly? Should the front sheetmetal be installed as a unit, or separately?
Should I not have installed the radiator support first?
I want to keep the paint scratches to a minimum. So any help will be appreciated.
I just put the front fenders back on my '48 panel. It would have been alot easier with a helper. These are old and dented, the screw holes don't line up. I would suggest installing the inner sheets first and adding the outer, work with lighter parts. put all the bolts in but don't tighten any until they're all in and the panels are positioned correctly.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
installing the rad.support first is the way to start as everything hangs on it. Tape plenty of tape will help prevent those scratches.
http://s933.photobucket.com/albums/ad179/OEM54/
Keep the radiator support bolts loose as well where it bolts to the frame. This give you a little play for lining up all the parts.
On my 53 it was easier to bolt the inner and outer fenders together and then install as a unit. If you have the year truck with the fender rod supports that connect to the fire wall these are great for lining things up. Exact length adjustments are in the manual.
Good luck
Rich
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
