1 members (delky), 130 guests, and 3 robots.
Topics128,062
Posts1,055,854
Members48,428
Junior Member
Junior Member
Still in the process of getting it "on the road again", and I want to check the oil level in the transmission. I see there is a plug in the bottom and one on the side. If I drain the transmission, what type of fluid/gear oil is best to replace it with and how full do I put it? I would think I should fill it until it runs out the top hole, but I am not sure.
Also, can anyone tell me which way to turn the adjustment wheel on the brakes to loosen them? Not a big deal, but could save me some time on the "old trial and error" thing.
It takes no talent, skill or effort to be different. What makes you special?
90wt gear oil, yes, till it starts to run back out the top [fill] hole - if you're going thru the adjustment slot, moving the outer end of the tool handle toward the center of the wheel expands [tightens] the shoes, to loosen, handles goes toward the tread
Junior Member
Junior Member
Thanks Bill. Much appreciated. I am going to adjust the brakes through the slot. BIG HELP!
Mark
