| | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56570 02/17/2006 6:30 PM | Joined: Jan 2006 Posts: 5 Junior Member | | Junior Member Joined: Jan 2006 Posts: 5 | Still in the process of getting it "on the road again", and I want to check the oil level in the transmission. I see there is a plug in the bottom and one on the side. If I drain the transmission, what type of fluid/gear oil is best to replace it with and how full do I put it? I would think I should fill it until it runs out the top hole, but I am not sure.
Also, can anyone tell me which way to turn the adjustment wheel on the brakes to loosen them? Not a big deal, but could save me some time on the "old trial and error" thing.
It takes no talent, skill or effort to be different. What makes you special?
#56571 02/17/2006 7:43 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 90wt gear oil, yes, till it starts to run back out the top [fill] hole - if you're going thru the adjustment slot, moving the outer end of the tool handle toward the center of the wheel expands [tightens] the shoes, to loosen, handles goes toward the tread
Bill | | |
#56572 02/17/2006 8:12 PM | Joined: Jan 2006 Posts: 5 Junior Member | | Junior Member Joined: Jan 2006 Posts: 5 | Thanks Bill. Much appreciated. I am going to adjust the brakes through the slot. BIG HELP!
Mark
