1 members (Shardean), 113 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#565015 08/14/2009 5:33 PM
Can you confirm that it is a 8.5 inch, 10 bolt?
It has AJ 127 (3.70:1 ratio) and 3707340 2D on it.
http://img194.imageshack.us/my.php?image=1001456s.jpg
'59 Apache
'67 Mustang
It is not the 8.5" 10 bolt. It is the 9.375" 12 bolt, used from '55-'62. The AJ code may actually be a 3.90, rather than a 3.70. If you're checking from the same source I'm using, there is a typo on the '59 specs, it lists it as a 3.70. Same code for '58 is 3.90, and the shop manula makes no reference to a 3.70 gear. The only options were 3.90, 3.38, and 4.10. There was also a 3.92 gear, but that was the optional Spicer 45 Positraction axle, a one year only option on Chevrolet (was the standard equipment rear, with or without Posi, on GMC).
Bill Burmeister
Bill, I am a little confused. There are 10 bolts on the Diff. Cover, not 12...
'59 Apache
'67 Mustang
Apache,
Some of the confusion could be coming from that fooord thing in your signature. LOL wave
Here are 2 pages from the 58 & 59 Resto Pack that should help. http://chevy.oldcarmanualproject.com/chevyresto/58t083.htm
http://chevy.oldcarmanualproject.com/chevyresto/59tsn02.htm
-Tom
1950 Chevy 3100 w/ 1956 235
the only way to be sure is to take the cover off and get the numbers off of the edge of the ring
I need the information because I wanna buy an installation kit (pinion bearings, seals,...). It is really necessary to take the cover off?
Summitracing.com wants to know the size (8.2" or 8.5") and the bolts. Thats it.
@Oilrag
isn't the 235 a 6-banger? I have 16 all in all ;-)
'59 Apache
'67 Mustang
Summit is probably not the best vendor for something like this. They are oriented to more recent car stuff.
While the number of bolts holding the cover on is a convenient way to identify many GM rears, its not they way they did it back in the 50's.
aside from jacking it up and counting revolutions, wheel/ driveshaft, it's the only way to be absolutely sure, bec you don't know what anyone did prior to you owning the vehicle. you don't even know the condition of what's there. what if there are very worn/chipped teeth, or the shims were incorrect and the wear pattern is off? bearings and seals won't cure that
You might want to give Patrick's a call. They carry a kit that has all the bearings and seals in it.
The cover does throw people off sometimes. While the cover has 10 bolts, the ring gear is 12. Summit does not carry parts for it, nor does Jegs. Also, disregard the limited slip units they list that fit "'62-'76" 12 bolts. They are only good for mid '65-'76. The '62 is the '55-'62 design (like what you have) and the '63- early '65 have a different spline count.
Bill Burmeister
Don't you have to pull the cover to work on it?
Clean it out with the cover off and replace the oil, so when you are ready to work on it, it will be some what cleaner.
